How to tell if M.C is going out?
Discussion in 'The Garage' started by dleroy43, Jun 19, 2004.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have bleed them and recently replaced the rear shoes. the fronts are still good but it doesent stop as good as the first couple days. the rears will lockup it stomped on but normally it stops like a boat. Theses brakes are 2x the size of the old and take 2x as long to stop. Anyone have some suggestions? /forums/images/graemlins/confused.gif /forums/images/graemlins/burb.gif
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    whats the pedal feel like, hard or soft. May just need to bleed them again, and again.
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Try and bleed them again. If everything wasnt new or cleaned surfaces when reinstalled, it may take a few miles for them to seat in. I run carbon metallic pads and metallic shoes on my vehicles and sometimes it will many hard stops to get them to break in.
    A typical symptom of a failing MC is the peddle will slowly start going to the floor on its own.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you don't have the shoes adjusted correctly you won't have any pedel. You need to make sure the shoes are fairly close to the drums, then apply the brakes hard while going in reverse a few times to let them self adjust.
  5. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    the pedle is softer than before. when I push hard it feels like somthing solid stoping the pedle but the truck still rolls without the braking I would expect. I tried adjusting the rears by going backwards but Ill do it agein and bleed them some more to see if that helps
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sign that a m/c is going bad is pedal sinking when holding truck stopped, and also if is leaking out the back of the m/c and down the front of the booster
    sounds like you may have alot more bleeding to d, it might be that you need ot bench bleeed the m/c more, i hope you have bench bled it before installing it,
