How to tell if Possi or not ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Executioner, Sep 19, 2000.
  1. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Plain and simple
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You could pull the cover and look, or you could jack up one wheel and try to spin the other. However, if the posi is worn, this will not work</font color=blue>
    http://www.chrisd71k5.coloradok5.com <font color=blue></font color=blue>
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Hook a tow strap around a tree and use throttle until you spin the rear tires. If both rear tires spin=possi. If only one=not
  4. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Light those meats up and you'll find out...
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
  5. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    I hear if you jack both tires up and spin one if the other tire spins the same direction it is posi if it turns opposite it is limited slip. Is this right???
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    take your diff cover off and look at the carrier.. If you see a mostly closed piece of iron with springs and clutches, then you have a Gov-lok...
    If you open it up and you see the carrier with two large open spaces in it and you can see (4) spider gears and the center pin, then it is an open carrier...
    I am assuming you are talking about a factory rearend..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  7. Executioner
    Feb 22, 2000
    1,530
    What are spider gears ?
    Which ones are on the top and bottom ?
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Spider gears are on the inside of the carrier. They are what creates the 'differential' effect of the rear end. My carrier is open and some of the spider gears fell out when I took out the cross shaft to remove my axles. I was able to see what locations they came out of and had no problem getting them back in. I did notice that they had some shims underneath and I was sure to get those back in.
