how to tell if shocks are bad?
Discussion in 'The Garage' started by tecton, Mar 30, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ride feels a bit bumpy at different speeds
    mabye time for newbies?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    When you hit a bump and are still bouncing from it 1/4 mile down the road, you've got bad/worn-out shocks.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    If i'm suspecting a bad shock, i usually will remove the lower bolt of the shock and see if it compresses way too easy, i have had a bad/broken shock on the front once, and it did not do this bouncin down the road thing as previously mentioned, it just felt like the truck would bounce in a weird manner when a big bump was hit, basically like one side was too soft or something.
    That is the best way so that i have found how to check out the shocks, doesn't take much time, just need the motivation to work on it. /forums/images/graemlins/thumb.gif
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Here is a wierd trick, but it works...
    Rub chalk all over the surface of your tire and take it for a short drive If your shock is bad, you'll see a "skipping" pattern in the chalk. If it's good, it'll all be gone.
    I know..wierd..but it works..
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    another thing you can do is jump on the corner that you think is bad and if it bounces to much (more than twice) that corner is bad /forums/images/graemlins/waytogo.gif
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Ya see, /forums/images/graemlins/thinking.gifthis didn't work on my ride, as the lifted spring were too stiff to be able to tell this about the shock. /forums/images/graemlins/doah.gif
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If it feels like you are on a 15' aluminum boat in the middle of the pacific every time you go over a bump than you need new shocks. /forums/images/graemlins/whistling.gif
