how to tell if they are 4.10??
Discussion in 'The Garage' started by 85mudblazin, Jul 7, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am wanting to get a 14bff and I need to know how to tell if it has 4.10 gears.
    Thanks-
    -Chris
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When you pull the cover to inspect it PRIOR to purchasing it , on the side of the ring gear are numbers , get those and you can tell what gears are in there. Usually it is something like 41 and 10 , I.E 41 divided by 10 /forums/images/graemlins/k5.gif
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    An alternative method to what Paul suggested:
    Hold one wheel still. Rotate the free wheel 1 rotation, and count the number of turns the pinion yoke makes. Generally it will be some standard gearset like 3.73 or 4.10
  4. chevy_addict
    chevy_addict 1/2 ton status
    May 4, 2004
    138
    You are here, I am not
    Silly newbie question: why hold one wheel still? /forums/images/graemlins/confused.gif
    Dave
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If its not a real locker or welded, the other tire differentiates and the driveshaft won't turn /forums/images/graemlins/k5.gif
  6. chevy_addict
    May 4, 2004
    138
    What if both wheels are raised and the driveshaft is turned by hand, will the results be the same as one wheel held still? Or will it be half? I tried both wheels raised on my 14bff and came up with a stupid number: about 2.25 driveshaft revolutions for 1 tire revolution.
    Dave
  7. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Double it for one tire rotation. Does 4.56 sound right?
  8. chevy_addict
    May 4, 2004
    138
    4.56 makes a lot more sense than 2.25 /forums/images/graemlins/smile.gif
    Dave
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If the wheel can be turned with only one wheel raised then you rotate the tire 2 times.
    If it is a spool or welded and both wheels have to be raised in order to turn it then it is only one revolution of the wheel.
