How to tell if your BLOCK is ready for a Turbo?
Discussion in '1982-Present GM Diesel' started by AzzKicker, Sep 12, 2002.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    I keep hearing things about before adding a Turbo to a 6.2L make sure your block is good. How would I go about checking this.
    Truck runs great, no smoke, no sputtering, no stalls, etc. Theres a little bit of smoke at startup, but it last like a 3 seconds.
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Disassemble your entire engine, have the block hot tanked and checked for cracks by a machine shop. While you've got it apart, you might as well rebuild it.
    Nuke the site from orbit... It's the only way to be sure.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    If you want to have peace of mind, remove the oil pan, and wipe down all the main bearing webs really well. Let it sit for a while, come back and look at the webs. Any cracks that might be present will be noticable by the oil that has seeped into them. If you have a lot of cracks, you may not want to turbo it.
    Personally, I wouldn't worry about it. If it's gonna fail, it's gonna fail with or without a turbo. Just put one on it and go, man!
    The other thing is to make sure you have the newer style rear main seal. The early style was a rope-type seal. The newer one is a rubber seal. I don't remember when they switched to the newer seal.
    The turbo will add more crankcrase pressure, and it's been know to blow out the rope-type rear main seals.
    Casey
