How to tell ring size on a 10 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by will89, Jan 15, 2003.
  1. will89
    will89 1/2 ton status
    Oct 21, 2002
    104
    nomad
    How can I tell which ring size I have on my 89 1/2 ton front axle without taking off the diff cover? Are there any numbers stamped on it that would indicate size?
  2. dyeager535
    26,979
    it's 8.5", all of them are. (10 bolt truck axles that is)
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    He meant ratio I think. /forums/images/graemlins/grin.gif
    If so. The only way without taking off the cover if you don't have a tag on the cover, is to mark the driveshaft with a chalk and the same on the tire, then rotate the tire and count driveshaft revolutions and multiply by 2. Unless you have a spool or a locker that is engaged then you don't multiply by 2. /forums/images/graemlins/thumb.gif
  4. will89
    Oct 21, 2002
    104
    nomad
    thats it! thanks
  5. will89
    Oct 21, 2002
    104
    nomad
    Do you know if these axles have inner seals at the diff? I was just told by a gear shop that the only seals they have are at the wheel side of the axle????? Anybody know??
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    There shouldn't be any seals on the inside since the bearings at the end are lubed by the gear oil which should fill the tubes.
    On the full floating fronts you have a seal on the inside. /forums/images/graemlins/thumb.gif
  7. will89
    Oct 21, 2002
    104
    nomad
    Good.. so thats one less thing do. Now its just ball joints, u-joints, brakes, bearings, and the outer seals. Should be about a 15 to 20 Pabst job.
  8. Grim-Reaper
    7,385
    Atlanta
    add FULLSIZE to that. S trucks and cars run a 10 also with a smaller ring.
  9. dyeager535
    26,979
    Of course, add SOME to that, and you'd be correct lol.
    Just thinking about some of the newer S10's and big cars that got 8.5's as well. But yes, I should have said "1/2 ton" (unless S-10's are considered half??) to make that clear. There were 8.2" 10 bolts back in the day as well, but those don't count. Car diffs.
  10. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    He said "front" and the S10s had 7.2" ring gears in their IFS "axle".
    Many S10s are 1/4 tons. Quite a ew are 5/16 tons. 1/2 tons were available. I had an 89 Sonoma with the 2.5L and 1/2 ton springs. Power brakes but no power steering. Was kind of nice to have a lot of weight in the back end because it was easier to steer.
    There are tons of 10 bolts. All the way from 7.5 to 8.6 now. The originals were 7.5, 7.625, 8.2, and 8.5. Now there's a rumored 8.6" floating around in fullsize trucks.
    I have yet to finish it yet but here is one of the pictures I give people for axle identification. [​IMG]
  11. dyeager535
    26,979
    Yes, and since its an '89, it could have been IFS, but isn't /forums/images/graemlins/smile.gif
    I wonder if the 8.6" is the one that LOOKS like the 8.5" our trucks got, but I've noticed one easy to see difference on the newer housings, the "ears" on each lower corner of the center section are shaped quite a bit differently. Only on the new trucks, somewhere around 2000+ or so. Perhaps this is just a redesign of the 8.5", and the 8.6" is totally different.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    8.5" rears been around since muscle car era, cars been getting them ever since, novas, camaros, caprices, impalas, trucks, vans, so forth, soe were 4 3/4" pattern and some like under B body wagons and 9C1's were truck 5 on 5 pattern
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Just FYI the 14SF gasket pic is turned 90 degrees wrong. It's oval the other way dude... /forums/images/graemlins/grin.gif
    Rene
  14. dyeager535
    26,979
    The 8.5" "corporate" 10 bolt rear was first available in 1973, and from what I've found on the 8.2's, all *but* Olds had 8.2" ring gears before that(pre'73), Olds had 8.5's.
  15. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Yeah, I know. I scanned them off something a long time ago and never finished it. GM axles are easy to spot, it's the Chrysler and Dana axles I'm more worried about. I threw it all together a while ago. The 8.2/8.5s need to be finished also. The truck one is the only one that had the big square ears and used the cover gasket on the LEFT.
    Sometimes I wonder about myself. I think all this reading for my 4 EE courses I have this semester has my brain fried.
    It'd be a mighty funny looking differential carrier if the 14SF was shaped like that... /forums/images/graemlins/grin.gif
  16. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I fixed the diagram... /forums/images/graemlins/grin.gif
    [​IMG] </font color>
  17. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    If we're talking a solid axle 10 bolt front rear it has seals in the axle tubes at the center section, not at the ends, the front wheel bearings aren't lubed by differential oil. To change the seals you have to disassemble the front diff and change them from inside the housing.
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    all 8.5" car and truck both, have square ears on 5 and 7 o clock positions, the 7.5" have lil fangs like the s-10s and light duty application cars
    there are some 10 bolts that have what they call B&amp;O type axles- they have bearings pressed to shafts instead of located in the axle tube ends retained by the wheel seals
    but yeah, we actually should be answering with front 10 bolts since this thread was aimed for them originally, all 8.5" have the square ears no matter if front or rear or car or truck, the 8.5" diff housings all look identical
