How to tell the difference between a 205 and 203
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan88Jimmy, Dec 22, 2000.
  1. Ryan88Jimmy
    Ryan88Jimmy Registered Member
    64
    Winnipeg, Manitoba, Canada
    How can you tell the difference between a 205 and 203 tcase with the id plate off? and without getting inside of the case.
    thanks
    Ryan
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Theres a small plate on the back held on with 3 bolts. its in between the large round cover and the rear output</font color=blue>
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The shift pattern is different for one. On the 205, the shift pattern from far front to rear is: 4low/neutral/2high/4high. The 203 is: lowlock/low/neutral/high/highlock. The 203 typically has a large round aluminum extention on the rear of the case where the rear drive shaft comes out. Also, if your vehicle doesn't have locking hubs (auto or manual) it is the 203. I'm sure there are other differences but can't remember 'em now. chow
    Fencepost eater
  4. rezalb
    rezalb 1/2 ton status
    Apr 6, 2000
    207
    Phoenix, AZ metro
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    203 is much bigger too.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
