How to tell the difference between v8s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mud390, Nov 6, 2002.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I have a 77 k5. The vin codes the engine to be a 305. When I purchased the truck I was told the original engine was replaced with a 350, which is obviously a much better engine. I really don't know which engine is in the truck. What is the easiest and most accurate way to tell which engine I have? I know its not a 400 because it is not externally balanced. Thanks for your help!
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    My 350 was stamped with a 350 on the block, I forget what side, just under the exhaust manifold if I remember correctly.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Casting numbers on the block. This will tell you the type of block (350, 305, etc) but it won't tell you things like if it's stroked, bored, bumped compression, etc. Then do a search on the net, there are several sites for looking up casting numbers, I'm sure somebody will know off the top of their head (unforetunately I don't).
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Heres a great listing of Chevy numbers:
    Mortec
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Casting numbers can only tell you so much. They used same cast numbers for different displacements. What you need to do is get the suffix code along with the casting number.
    I have an extensive list of suffix and casting codes if you need help.
  6. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Put Yer foot in it...you'll know if it's a 350 vs. 305. /forums/images/graemlins/thumb.gif
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Do you know of an online source for the suffix codes?
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. I bookmarked it. /forums/images/graemlins/thumb.gif
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    quickest way i tell is by the balancer size, if its 8" diameter and about 1.5" wide then its 350, if its about 2" wide and 7" diameter then its 305
    400 use same size balancer as 350 but has solid back instead of hollw back
    307 327 283 265 all use tiny skinny balancer
    but even this rule of thumb has loopholes, previous owners can swap wrong balancer on SBC
    good luck
  11. mud390
    Oct 31, 2002
    1,210
    Thanks for all the info. I will definately be crawling all over the motor this weekend checking on all the things you guys listed. Thanks again!
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You're welcome /forums/images/graemlins/thumb.gif
