How to test for head gasket leak?
Discussion in 'The Garage' started by BurbinOR, Aug 9, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Buddy of mine has a 400 in his 2wd pickup...............loses coolant but can't find a leak. Any idea how to check exhaust or spark plugs for signs of a head gasket failure before it becomes a bigger problem? /forums/images/icons/crazy.gif
    Thanks............
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It will make the engine oil get foamy and look like chocolate milk if it's bad enough. I've also heard something about it making the exhaust smell sweet. A hesitation under load is also an indicator of a blown head gasket. </font color>
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    like shaggy said sweet exhaust( the smell of the burning coolant) and pull the plugs and crank it over, water should be coming out of the guilty cylinder, also pop the radiator cap, coolant will be foamy.
    -Jeremy
  4. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yeah a blown head gasket will turn the oil into chocolate puddding, and the antifreeze will do the same...
    i blew one on a car and white smoke came out and smelled like burning antifreeze...
    but if its losing a decent amount, you really should be able to smell it or see the change in the oil and antifreeze, i'd change the oil and check it out...
    might want to check the heater core too, i know when mine started leaking i saw that i was losing coolant but didnt see any marks in the engine bay, so i pulled up the carpet and found a nice wet spot under it...probably not the case but it only takes a second to check..
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I had a blown head gasket that was putting compression into the antifreeze. Antifreeze was leaking into the overflow bottle and then to the ground. Took forever to figure out what was causing it.
