How to test glowplugs?
Discussion in '1982-Present GM Diesel' started by kennyw, Nov 21, 2004.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I set up my glow plugs as fully manual with my new 6.2 swap. The truck started great the first couple times now it seems I might have burned them out from holding the button too long /forums/images/graemlins/doah.gif Anyone know how to test them individually? If money wasn't an issue I'd just replace them all at once right now and be done with it, but we all know how that goes... Right now I want to replace any of them that test bad then replace the rest as soon as I can get the extra money.
  2. kennyw
    Jun 9, 2002
    13,224
    94
    Nevermind, found it in another post /forums/images/graemlins/thumb.gif
    Heat in the cylinders. This is aquired through the glow plug system. Testing this can be done by disconnecting one glow plug at a time and putting a cheapy test light between the wire and glow plug terminal. If it lights when the glow plugs cycle that plug is good. Check all 8.
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Hopefully none of the tips swelled on you...
    Rene
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Actually, an easier, similar way to check the plugs is to clip the test light to the POSITIVE side of the battery, and then touch the light to each glow plug terminal, with the glow plug wires removed. Again, if it lights up, that glow plug is good.
    This method is pretty much the same, but doesn't require cycling the glow system.
    Casey
  5. kennyw
    Jun 9, 2002
    13,224
    94
    Casey
    And alot easier to test by myself when my glow plugs are fully manual anyway (switch in the cab), thanks /forums/images/graemlins/thumb.gif
