How to test power window...........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Feb 27, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I thougth it was a switch and it was not that so. Next up would be the motor. So how do i go about it? thanks
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    A quick way to see if it draws power is to turn the dome light on and press the switch. If the light dims, that means the motor IS getting power and TRYING to work. A quick power draw test. If it doesn't dim, You more than likely have a wire problem. Is it just 1 window?? It's common when the trucks get older that the wires that go to the door, through the jam, break from the constant flexing.
    other than that, is to pull door apart and do a voltage drop test AT the motor.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    its just the one window. OK i will test the motor. thanks
