how to tick the o2- sensor
Discussion in 'The Garage' started by 79wheeler, Jul 22, 2005.
  1. 79wheeler
    79wheeler Registered Member
    Jun 24, 2005
    19
    az
    Hey all, This question is not regarding a <blazer>..OK we had to take out my buddys cat. because the honeycomb came loose and was heating up the dodge.So a new one is around 200 because it 3 inch. pipe.so we hollewd it out .. truck cooled down and runnig much better! Well the problem is the o2 sensor keeps setting off the check engine light..there is two of them one in front of the cat and one in the back.the back one is setting off, because what we did . so how do u trick ethier the sensor or the computer? what does it read ? I konw unburned oxygen. so how do i trick it ??? :confused: thx guys
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Jeg's sells a O2 sensor bypass that simply plugs into the harness replacing the sensor...........now that you've fooled the computer into thinking the O2 sensor is functioning correctly how do you adjust the fuel mixture? :doah:
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    An O2 sim on the sensors BEHIND the cat is perfectly fine in my eyes. I wouldn't run one before the cat...the sensors after the cats have nothing to do with how the motor runs, but just shows if the cats working right or not, and sets off the check engine light...the sim should fix the SES light prob and not make the motor run any way it shouldn't.
