how to trace a short?
Discussion in 'The Garage' started by darkshadow, Sep 13, 2004.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    ok my dash lights have been out for a wile now, keeps poping fuses right when i turn them on, when i had my whole dash apart last night, i checked them and they worked fine. When i put it all back togeather it pops them again. so how do i chase this???
  2. dyeager535
    26,975
    Does it pop the fuse with the cluster out but the lights turned on?
  3. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    as i hit the switch it pops head lights fine, intirer lights fine.
    when i had the dash apart i olny unpluged the speedo caple and it worked fine. thought it was all ok, but as soon as i put it back togeather pop pop pop /forums/images/graemlins/dunno.gif
  4. dyeager535
    26,975
    You kind of lost me there.
    With the cluster out, does the fuse pop? That narrows the search by 50%. Either it's the harness to the cluster, or it's the cluster itself. If it still pops with the cluster out, (disconnected) something in the cluster is the likely culprit.
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    834
    Pinckney, MI
    i use one simalar to this! i picked it up at lowes for 40 bucks really easy to trace shorts
    Clicky
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Look at my DIRTYROTTEN... post, I'm experiencing the exact same problem!
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    sorry when i had the cluster out (but still pluged in)and the dash apart the lights worked ok, the only thing that was unpluged from the cluster was the speedo, and i had not disconected anything elce. that is why i dont understand. /forums/images/graemlins/dunno.gif
    and it is poping the fuse even a 30 amp instantly. it dosent even last half a second
  8. dyeager535
    26,975
    First I'd pull the cluster, and with the light switch on, reach my hand in there and move all the wires in the dash around. If it pops, you know you've got a problem in there.
    If nothing from that, look at the cluster connector part of the printed circuit board, and make sure the copper hasn't peeled up and is touching another lead.
  9. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I wouldnt put more than a 5 or 10 amp fuse in the dash light curcuit--the printed curcuit can double as a toaster if you put more than 5 amps or so through it with a dead short--ask me how I know this /forums/images/graemlins/ignore.gif.Did you check all the bulb sockets in the dash?--some of them have a thing that holds a fiber optic cable thing that shines on the ashtray and heater controls,that has a bare metal tab on it,its easy to accidently ground it out against the dash,also I had a similar problem on an older K5,I never did figure out why it blew fuses occasionally,but at my brothers suggestion I installed another ground wire right to the dash cluster(drilled and sheet metal screwed a wire to the metal part of the cluster)and it never popped again,but I was never sure if thats what fixed it,or removing and installing the cluster --maybe a wire was pinched,dont know for sure-. /forums/images/graemlins/dunno.gif
