How to tune a carb for hills? search didn't help!
Discussion in 'The Garage' started by backyardbuilt, Jun 1, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    How to tune a carb for hills? search didn\'t help!
    I have just gotten into real trail riding and hills/rock ledges and my carb is giving me fits. It runs great on the street and in the mud but get it on an incline and it dies. It is a holley 3110 with the dual metering block upgrade. I think the floats need adjusted from what I have read on other boards but want to hear what more people have done. I know carbs are not great on hills but have seen them work 10 times better than mine.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: How to tune a carb for hills? search didn\'t help!
    Most Holley carbs don't work worth a darn once the truck starts bouncing and/or is on a steep hill. The stock Quardajet carbs are much more forgiving off road. /forums/images/graemlins/shocked.gif Holley sells a lot of special parts to make their carbs work better, but it isn't cheap to do them all. Spring loaded needle and seats, slosh baffles for the bowl vents, and special float bowls.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    replace it with a TBI setup from a big block...
    Grant
  4. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I would do that if I had cash, just want to get it better for now.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    lower the float levels as much as possible.
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    connect both of the fuel bowl vents together with a piece of 1/4 inch hard line with a slight bend in it to clear your air cleaner stud...make sure you drill several small holes in it cause they need to breath,the stock breather tubes should stick up enough to sleeve them to attach the new tube..this works on edlebrock and carter carbs also /forums/images/graemlins/thumb.gif this wont cure all the probls with the holley but it will help ..you can also lower the floats to just below the site holes in the bowls without running it out of fuel...
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    My floats were at different settings would that cause problems too.
  8. leadfoot067
    May 14, 2001
    1,563
    yeppers
  9. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    i think my float are off also, it's stumbling around corners, when i make fast stops, and it's worthless off-road it stalls on slight incline. While i'm lowering my float bowls i wanna do this, do you have a pic?
  10. texas78k5
    texas78k5 Registered Member
    Apr 24, 2005
    26
    Kerens, TX
    Having the same problem, I just recieved the #1465 Edelbrock "needle and seat" kit from Summit . Edelbrocks site say set the floats at 3/8" and instructions included says 7/16"?????? We'll see!
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    if TBI or something like that is not a good alternative due to cost... look into a holley truck avenger... I like mine.... havent got it in supreme angles yet... but I did have to enter a tight trail (where a dozer put a berm) and I was aiming upwards.... so far I love this carb (when it is warm as the choke sucks) :grin:
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Old Timers trick- slip about 12" of fuel line over the vent tubes, and leave em coiled up inside the air cleaner. Keeps fuel from coming out the vent tubes and flooding the motor.
  13. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I have herd that swaping to a Q-jet while using an square bore adapter so you can spin the q-jet 180 degrees around works realy well because of the q-jet's fuel bowl design. Don't know a hole lot about the setup however...I use a truck avenger.
  14. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    I use a holley with lowered float and this idea but I use a rubber fuel line to extend the vents. No problem on hills or off chambers!
  15. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    carbs and wheelin mix like oil and water
    if you want i can get you a 350 with TBI and computer ..will not smoke..1000$
  16. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    3310 Mods
    I'm running a 3310-1 on my BBC402. For off road running I've added the whistle float bowl vents, spring loaded needle and seat. Float bowl vent extensions are also a good idea. Overall, give the $ and T invested it would have been better just to find a cheap TBI setup - diminishing returns.
    The mod'd 3310 runs well on fire roads and modest off camber stuff but I have no intention of more extreme usage (yet).
  17. rcamacho
    Jul 1, 2004
    1,324
    WA
  18. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    find someone with a street-only truck willing to trade your holley for a q-jet. mine has never given me any trouble on inclines. last time i was out, i stalled it once when my front end slammed down from about 3' up (long story), but i was able to start it back up immediately. some of the tricks mentioned on here are good, but they won't make it outperform a q-jet or a truck avenger offroad.
  19. rcamacho
    Jul 1, 2004
    1,324
    WA
    Nah, I like my Holley. Absolutely no problems offroad on side angles or hill climbs. I know how to tune them and no electronics to fail. If I swap I'll go the TBI route.
  20. sta500666
    sta500666 1/2 ton status
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    Here is what I told another guy with the same general questions in a different thread:
    I originally ran a rochester q-jet and it worked great off-road but it was old and then started leaking really bad so I picked up a brand new Edelbrock Performer and it ran awesome until I tried to go up a hill, or I hit a bump... Also when they die and get flooded they are a B*tch to get started again! They will go up any hill backward tho(only know from experience from otherwise being stuck going forward). I was then going to get TPI becuase I have a thing for corvettes and u can get a lot of power out of it, but it was ganna cost me about $800 and a lot of time. So I watched ebay for about a month for a Holley Truck Avenger 670 cfm and after loosing a couple of bids I finally won one for $162!!!! Bolted it on, fired right up, and it can take on anything I can throw at it!!!
    By far the best carb on the market as far as dependability and price go!
