How to UN-LIFT a first gen blazer?
Discussion in 'The Garage' started by chevy_muscle, Mar 22, 2004.
  1. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    I'm wanting to buy a first gen blazer, but all the ones that I've seen in my price range are lifted.
    I like the stock hight of these blazers, so I'm wondering how much trouble it is to restore one back to the stock hight.
    I'm guessing it depends on the method of lift, but I don't know much about those methods, so can you fill me in?
    Thanks!
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    two kinda os lifts, all spring, or spring front and blocks rear
    if you have blocks rear its simple, unbolt u-bolts, remove block, install new u-bolts, now removing springs can be tricky i've heard. but if you have all spring lift, you just have to remove the springs and install new ones, also depending on amount of lift things like steering componants and drive shafts might have to be swapped to stock length pieces also /forums/images/graemlins/peace.gif
  3. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    i have some stock front springs if your interested.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Or if it has a body lift you have to pull the puck's out put in new body mount bolts and make a few other minor things like a see what they did to the fan shoud and stuff like that... Not to hard to usually UN-lift a truck, and you can probably find someone to trade you all your lift stuff for there stock stuff
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    You'll prolly run into all the problems that most of us ran into while liftin our rigs. Probably have to shorten at least one driveshaft plus maybe a steering drop arm. Do yourself a favor and try drivin one with the lift and what not. You very well might find out that you like flyin a bit above stock. Good luck to ya in the future.
    Allan
  6. chevy_muscle
    Mar 16, 2004
    103
    Murphy, tx
    Thanks for the help guys, this is a great site!
    /forums/images/graemlins/k5.gif /forums/images/graemlins/dunno.gif
