How to undo what I've done
Discussion in 'The Garage' started by Disturban, Apr 16, 2007.
  1. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    The rear pinion seal was leaking ,took off yoke.Was surprised at how loose the nut was having done one once before that was tight as tight can be. Replaced seal,yoke,and then made sure that nut was good and tight! Well guess what...now I find out that I prolly messed up the bearing load and the crush sleeve.Truck has a vibration it didn't have before. What now?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What gear ratio ? Sometimes another axle is easier .
    Although , knock on wood , I have no trouble with an axle built at home . Nate and I did mine in my garage after Moab .
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you should be replacing the pinion nut when you do that as well. here is a simple question though. Is the driveshaft balanced? If so, did you index it when you removed it? You may well have screwed up the preload, but its not unheard of for a driveshaft to be installed in the wrong position and cause a vibe.
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I agree, rotate drive shaft 180 degrees and drive it again to see if vibes go away. Also don't overtighten th u bolt straps.
  6. Disturban
    Mar 9, 2006
    120
    Phx,Az
    cool..I'll give that a shot,since it's the easiest!
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Look on the bright side , even if you do a little work to the Burb , you wheeled all day yesterday , and drove yourself home :waytogo:
  8. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Well, you could go back and do Woodpecker backwards in reverse... That'll undo everything that happened :D :haha:
    Just kidding, dude!:wink1:
  9. Disturban
    Mar 9, 2006
    120
    Phx,Az
    hehehehe...wow,yer a lotta help! How the hell are ya?!
  10. Disturban
    Mar 9, 2006
    120
    Phx,Az
    "Look on the bright side , even if you do a little work to the Burb , you wheeled all day yesterday , and drove yourself home :waytogo:"
    Yup ! Anytime you can get it home is a good day:)
  11. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    :haha:
    Ehhh... :D I'm leaking from the rear diff too. Power steering is worse so I'm gonna get the steering pump from Pauly soon. It was real good to see you out here, had a blast wheeling with ya!
  12. Disturban
    Mar 9, 2006
    120
    Phx,Az
    Welp..rotating the shaft seemed to do it...at least helped enuff to not notice it.Hafta test drive some more.Thanks guys.
