how'd this happen?
Discussion in 'The Garage' started by mtnman210, Oct 3, 2005.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Is this just the upper balljoint gone bad or do I have another mess to deal with? The steering arm has pushed up against the knuckle and worn a nice groove in it.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i thought thats the way they are. i think the steering arm is cast with that notch in it.
    either way an easy way to tell if you bj's are bad is to jeck the front tire off the ground and grab the tire at the top and bottom. push and pull. if there is any hplay the need to be replaced
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    see I didn't know if they are suppose to be like that or not. I new they were close but it looks like it's been rubbing pretty. thats how I noticed it in the first place the steering wheel locked up and I couldn't turn it and then all of a sudden it released so I figured thats where it's getting hung up. I'll try the jack today.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I've never had one rub like that. MAy want to check and see if you have play in your balljoints.
  5. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    They are cast with a notch in them. But I dont think they're supposed to sit that close. Here's a shot of mine...
  6. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thats what I thought.....yeah there's definitly something wrong
  7. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Mine is doing that now and was doing that a few months ago... both times were the upper and lower balljoints on mine. :o
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    dont skimp on parts . get moog joints as thay offer the problem sover line of good stuff. you get what you pay for.
  9. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    ok never done this before so quick question; I have to pull the front axle to swap the ball joints right? there's no way to get it out with the ujoint still there it seems like.
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    yep buddy. all parts from the knuckle out come off. need a b/j press also.
  11. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    you are correct.
    you probably can get a loaner ball joint press from either advance or autozone
    ryan
  12. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thanks -------back outside:doah:
  13. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    i used the HF bj press for mine. its not the fastest but it sure got the job done right.
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you dont have a BJ press, you could also use a BFH and a piece of pipe. Thats how I've done all mine.
  15. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    For the money I don't think you can beat Spicer(Dana) Ball Joints ! :bow:
    FYI make sure you understand Upper Ball Joint Preload ! :what:
  16. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    I remember prior to a year or so ago they didn't make replacement balljoint bushings for the Porsche I had. We had to replace the front control arm every time, ~300 dollars each time. Thank god I'm no longer dealing with that!
  17. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    and that would be?
  18. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    my lift arm from roughcuntry .didnt fit.i had to grind it down at that spot.!!
  19. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    SO it turns out that you push ball joints from inside the knuckle out:doah::haha::haha::haha:
  20. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    uh yeah lol.
    also if you cant get your hands on a press and dont want to smash them.
    look in your chiltons or hanse manual there is a trick where you use a large sockit and bolt and a washer to push it in/out cant really remembe but it is in there
