Howdya recalibrate your electric speedo?
Discussion in 'The Garage' started by angrysnowplow, Jul 31, 2003.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Can't find much info on this...Anyone know how to correct an electric speedometer in a 90 K5 with a NP241?
  2. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I had a 91 Suburban with a 241. The 241 has a electronic pulse generator in it. This signal is sent from the 241 to a device called a Vehicle Speed Sensor (VSS) buffer. You can order a new VSS buffer through your GM dealer. You will just have to tell them what your gear ratio is and the true diameter of your tire while on the truck. It cost me $100.00, but it works great.
  3. angrysnowplow
    Jan 8, 2002
    502
    MA
    Thank you sir! /forums/images/graemlins/thumb.gif
  4. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    No problem. Let me know what gear ratio and tire size I may have the one you need. I went through several differnt tire and gear combinations while I owned my Sub.
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Parts are NOT serviceable thru GM anymore...
    Call Instrument Sales And Service...info they will need..
    1) Gear Ratio
    2) Tire Circumfrance..make a mark on the tire and let it roll one revolution...measure and record...cal ISS with this info and they will burn a new calibrated drac for you. Drac (Digital Ratio Adapter Controller). You might ask if they can burn your current drac... located directly under the radio....
    DW
  6. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    K5 NUTT, Thanks for the correction on the name. I alway referred to it as a VSS, but after digging last night you are correct. It is called a DRAC.
  7. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    I looked last night and I have two DRAC's from my old Sub. One is for 3.73 gears with 35" Tires and one is for 4.11 gears and 35" tires.
  8. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Any idea on the cost?
    Great info guys!! /forums/images/graemlins/thumb.gif
  9. angrysnowplow
    Jan 8, 2002
    502
    MA
    I currently have 3.73's and 35's, but my 4.56 axles are going in soon. Thanks anyway.
  10. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    No problem. Hopefully this info helps.
  11. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    Does anyone have a phone number or email for Instrument Sales & Service?
  12. dyeager535
    26,982
    191
    If this is for the same thing, search for my "end all DRAC VSS" post I made not too long ago. You can fix it yourself for nothing.
