Howling Noise (posting for a friend)
Discussion in 'The Garage' started by NEK5, Mar 4, 2007.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Hey guys, my friends have a little issue with his truck. He has the same rig as me, 90 Blazer, 4" lift, but with stock 31"ers....He`s getting a howling noise, and he thinks its coming from the middle of front of the rig. He says it does it in 2WD and 4WD, but it gets noticeable worse in 4WD.
    Thanks in advance.
  2. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    A little more info, he only hears it when he lets off the gas...
  3. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Automatic ? Torque converter possibly.. they make noise when when you lift, when they are going bad..
    I would think diffs or transfer cases would always howl if they were the problem..
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Automatic...
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    check the slip yoke splines on the front driveshaft
  6. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    can he feel it or just hear it?
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    He didn`t mention being able to feel it...
  8. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    cause i have a noise on my truck when i let off the gas and i can feel it more than hear it but it may be because of the exhaust. i can feel it in the gas pedal like when i am on an exit ramp from the highway. so i just feather the gas to stop it i have no idea what it is.
  9. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    If it still has the Auto locking hubs make sure ones not engaged. Lift the front and spin each tire and see if the driveshaft spins.
  10. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    since yall speak of it my truck does sorta the same loud whining noise towrds the middle as well... only when im on the gas doing 70 but not on the gas enough to even keep up speed like where its barely keeping up with the drivelines and all
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Couple more things to add. He said that he can feel it in the floor boards, and that it usually only does it at speeds of 45 MPH +.
