hows a winch go on?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Oct 29, 2000.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i'm going to be building my front bumper soon and i need to know how to build a winch carrier, or what ever it is called. i plan on going with a warn winch. if some one can send me diagram or antthing with the bolt holes and basicly what i need to add to the bumper to put the winch in. so far i got a full brush gaurd and its a tub rectangular tube bumper so it will also be an air tank. what thiknes steel should i use? 1/8 inch to keep it light? thanxs for the help.
    Well as it gose it gose and under it rolls heavey rubber bouncing on a head.
    (hey i'm a poet)
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    If anyone has the info on the mounting bracket I could use it too. I am too poor to afford the winch right now and am building my bumper next week. Luke
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    man with all the people that have a winch i would think that there would be a bit more help with this. hey i'm to poor for a winch too man. just getting everything ready for later on down the road.
    (hey i'm a poet)
  4. fredd
    fredd 1/2 ton status
    127
    Madison, Alabama, US
    Go to http://www.ramsey.com/
    You will find a diagram with the bolt pattern, this is the same for Ramsey as for Warn.
    As for your airtank, DO NOT, repeat DO NOT use 1/8", that's to thin and it will leak or worse, explode under pressure.
    Use 3/16".
    I know it's heavier, but it's safer.
    Better safe then sorry.
    fredd
    4x4 Armor for your K5
    http://coloradok5.com/vendors/sec.html
  5. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    fredd
    Yeah that was a thought with the 1/8. originaly i was goingto use 1/4 thick but that would be way to heavy. what size do you use one your bumpers?
    (hey i'm a poet)
