How's this for a shackle angle?
Discussion in 'The Garage' started by zcarczar, Apr 8, 2005.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Well?
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Looks like you should take the ORD flip brackets and swap sides with them, that'll open up your angle to right about where it should be, looks too closed.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Would be good for droop, but I don't know how it would be for compression. Seems a little extreme, but I'm not an expert in any way. I would like to know what the universal "best" angle one would go for would be though.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    its perfect leave it the way it is.
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i'd drive it as is. see if they make contact or handle funny. if its bad, then swap sides.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'd leave it. It looks like your springs are almost flat the way it is (I could be wrong) so I don't think compression will be affected very much. Gonna droop like mad though.
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    looks perfect
  8. JohnyLowBuck
    JohnyLowBuck Newbie
    Dec 23, 2004
    Bay City, MI
    Looks just like mine. I kinda wondered about this myself. I've drove it like this for the last 6 months however and it rides just fine. I've even hauled some pretty heavy loads as i was remodaling my upstairs. No problems at all.
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Looks just fine. It will be a nice and soft ride and flex like a mofo.
    Harley
  10. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I stand corrected. I was under the impression that the optimal shackle angle was with the shackle as close to 90* to the spring end as possible. My shackle angle, which I thought was too closed is looking better now. :waytogo:
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Optimum anlge is closer too 45*. Its one of the things I don't like about the ORD flip, I think it could really do more for shackle angle.
    Well it depends on springs and shackle length. There used to be a calculation but I think it got lost when Echobit went under.
  12. Thuren
    Thuren Registered Member
    Apr 7, 2005
    16
    EIGHT ZERO FIVE
    It's an absolutely perfect angle for the springs you have IMO... :)
    Don
  13. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    Mofulgly13 where did you get those beefy shackles!?? Build or buy? Those are NICE! I want some!
    My ORD shackle flip put my angle pretty close to 90 degrees, my rig's flex in the rear is sweet, front not so good even though I have the ORD shackles up there, greasable bushings and TuffCountry ezrides.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ORD shackles only hurt front shackle angle. My shackle angle on the K5 was horrible with ORDs and BDS springs.
  15. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I built those shackles myself. They are 3/8 bar and have an offset built into them so I could run ford 57" long 3" wide springs. I'm still trying to get the K5 back together so I don't know how it will ride, but I am hoping for the best. It was actually pretty easy to make them after I had all the angles and measurements worked out. I used a porta-band, a 1/2" drill motor and my welder, and voila! I also used my lathe to drill the larger holes where the bushing sleeve ties the top together, but that's just 'cause I dont have a drill press. Apart for paying for material, the only cash I put out was to have them powdercoated.
  16. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Umm, there is something weird looking about that flip. At least, it looks much shorter, vertically, than my 4".
    Is that the 2.5" flip, or is yours modified from original ORD somehow?
    -- A
  17. zcarczar
    Feb 10, 2002
    2,495
    I was just showing off my bitchin shackle angle, I had no plans of changing it. I set it up when I did the suspension to be just like that.
    yeah thats a 2.5 flip, I still to beef these shackles up a big though before I run them.
  18. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    my shackle angle is pretty close to yours, wait till to you see how much droop you'll have. :D you are gonna need a limiting strap. i need to send my rear c.v shaft back to tom woods to get some more flex. i am running shackles like yours, been running them for a couple of years with no problems.
  19. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    I think my shackle angle is even steeper than that with the 57's. It rides great and flex's awesome. Last I checked I could get 45" under the rear tire...and that was with brutally stiff Rancho fronts.
    Rene
