HP Injectors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rich'90, Oct 2, 2000.
  1. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    I read on one of the posts where HP Injectors were mentioned. I have a 90 throttle body and was wondering if they would work with that. Where would I get them and about how much? Also, would I have to get anything else to accompany it like a fuel regulator, higher pressure fuel pump or a new chip? Thanks in advance for any help.
    Rich
    go heavy or go home
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    www.TurboCity.com has a killer TBI setup with all the stuff you are looking for. They also sell the different parts seperately. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's [​IMG]
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Hey! thanks for the site. It really helps me out too. I was looking for more stuff to do to my TBI.
    Heres a good site to get custom programed chips:www.fastchip.com
  4. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Squash yer right. If you dont at least have headers and hi perf exhaust any mods to the TBI are usually a waste of money. You can't use the extra air flow if you cant get it out the pipe. And you dont need a custom chip unless you start changing cams,Heads,comp ratio and that kind of stuff. I just threw the superchip site in cause they build some good chips and specialise only in GM
  6. rich'90
    Feb 27, 2000
    159
    Savannah, GA
    thanks for all the info. I have a 383stroker with headers and dual exhaust, so hopefully this will help it out with a little more power.
    thanks again
    rich
    go heavy or go home
