HP & Torque Guess???
Discussion in 'The Garage' started by high&liftedup, Apr 4, 2002.
  1. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    I just put it a new stock 350ci crate motor in my 76 K5. This is the motor that is rated at 250hp. I installed a (mild) x-treme comp cam, New Edel. Q-Jet & performer manifold, All MSD ignition, headman headers, K&N filter, everything else is new as well (water pump etc...... This truck is set up for med wheeling. The throttle response is great and through 4500 rpm it continues to pull well...
    Anyone want to give a guess on the hp/torque???
    Thanks....
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Well the 250 hp is with tube headers and open exhaust, so you can take the headers out of the mix as a power adder.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    "Flywheel" numbers at sea level:
    280 Hp @ 4800 rpm
    325 ft-lb of Torque @ 3200 rpm
    You gonna run it on a dyno?
    Marv
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    what size q-jet? what cam??? roller or hyd.?
    without cam number it is gonna be pretty hard to say
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I agree with Marv...
    Jim
  6. high&liftedup
    Nov 14, 2001
    64
    CA
    1)The Edelb. Q-Jet cfm is 750....
    2)Edelb performer intake.....
    3)The comp cam is the 12-235-2: 254/262 deg duration
    hydraulic.
    4) MSD Billet HEI distr, Super conductor wires, MSD off road box
    5) Headman headers and flows
    ..... approx 280 hp?????
    Thanks for all your inputs...
  7. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I would also agree... 280 ish
