HP vs. Regular Dana 44
Discussion in 'The Garage' started by Swanson52, Sep 26, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I assume the only strength advantage a high pinion 44 has over a standard 44 is the pinion/ring gear strength? Just checking.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I would assume the same thing, everything else is pretty much the same stuff. </font color>
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    and the high pinion---the driveshaft would be higer---and if im not mistaken i think i read somewhere that the "high pinion" makes the R&amp;P weaker---or was that "reverse cut"---
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    For pratical purpouses "high pinion", "reverse cut" and "Ford front" are the same thing. The pinion is above the axle centerline and when used in a front axle app it is stronger because the drive side of the gear is driven as opposed to the coast side that is driven in a GM front. This also makes it weaker in the rear. I know someone will chime in with all the proper terms and enginerring but in the real world of junkyard stuff you're looking at a Ford front D44/D60 or a TLC 8" front to get the high pinion or a full custom.
  5. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I already have the ford D60 for my own app, just proving a point to a buddy that wants to do the same thing (but has a 44 rather than a 60). He 'hears' about the people that have the answers on CK5, he just doesn't KNOW yet. He'll learn... /forums/images/icons/grin.gif
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    dammlt, i wish i had a dana 44, but i have a ten bolt for the front, i have no complaints tho, i i had the front fall 3 feet to the ground while off-roading, went off a 3 foot drop off at 25 mph by a pool and raquet club at 11:30, yea im crazy. /forums/images/icons/crazy.gif
