hp
Discussion in 'The Garage' started by jeff l, Sep 27, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I have a rebuild motor that should make almost 400hp with a rebuilt 700r4. I feel like the power is not getting to the wheels. I took it to a mechanic and he said he thinks its the trans, he would not have put that trans with a moter like that. he would put a t-350 or a powerglide. I am thinking i would rather a standard.
    what is your opinion? and is very hard to convert auto to stanard?
    3.73 gears
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I am running a 700R4 behind a 350 putting out 350hp/400lb.ft and do not have any problems. a 350 trans or powerglide are not really any stronger. a 400 would be better. is it slipping? how long ago was the rebuild? what makes you feel its not getting to the ground?
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Definately swap to the SM465, you will never want another auto ever again!!! :D
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the 700 would not really be any different from a 350, the 700 is based off a 350 tranny. and besides the 700 has a better first gear ratio and has over drive and lock up clutch.
  5. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    are you sure its a 400 horse SBC? was it dyno'd?
    are you maybe expecting something that was never really there?
    is it set up right? carb? timing?
    If something got messed you can turn a good engine into a dog in a hurry
  6. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    A 700R4 is fine. I'm running a 400+ HP 383 in front of a stock 700R4 and it'll plant your ass. If you're concerned about the transmission, there are plenty of upgrades available for the 700R4 now.
  7. jeff l
    Jun 13, 2006
    104
    New Orleans
    the trans was rebuilt the same time.
    its not slipping
    I just spent 10 k on rebuilding this truck ,and i would think 375 hp should spin the tires.
  8. jeff l
    Jun 13, 2006
    104
    New Orleans
    sorry if i sound dumb but what is SM465
  9. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    What size tires? If your running 35's with 3.73's and a locker you may not spin 'em. And like mentioned before make sure the motor is tuned right. Also a bit off topic if you dont already have one go out and get the biggest tranny cooler you can fit!!
  10. jeff l
    Jun 13, 2006
    104
    New Orleans
    I really wish i new more about all the trans, so bear w/ me. my 700 was paired w/ a 305. no offense to people w/ a 305 but it was a fuel and a smog conscience set up. the ratio is different, or should i say perfect ratio to a 305. I now through in a high hp motor. I just wonder is it working all in sync
    I am not saying the 700 is 100% to blame, i just thought this was something to think about.
    also i forgot to say the 700 rebuild has a shift kit and i had to put a different type lock up for my converter. b/c the computer does not control it
  11. jeff l
    Jun 13, 2006
    104
    New Orleans
    30' tires
    3.73
    eaton posi
  12. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    you should be able to roast those tires. at the very least it should bite and launch and snap your neck back. I am running 44's with 4.56/detroit and can spin the tires at will. TORQUE BABY! :bow: I can put the bumper against a wall and spin all 4 if I want. when I had boggers it wouldn't spin on dry pavement, way to much traction. what stall is your converter?
  13. jeff l
    Jun 13, 2006
    104
    New Orleans
    your gearing is also different , I have 3.73
  14. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yeah but your a running tiny little donuts.
  15. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    What are the specs on the motor? Compression, cam timing, heads, intake, exhaust? Did you copy someone else's build that was dyno'ed at 375-400 hp, or are you just guessing?
  16. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    If the thing has a carb I'd bet 100 percent it's not tuned right... carbs are very tricky without experience or good equipment. I couldn't count how many dyno runs I've seen where the right tune will give you another 40 hp... timing has a lot to do with it too.
    GM4CW: What are the specs on your motor? I'm guessing bb? spinning 44's with 4.56 gears is impressive... unless your using granny gear:D
  17. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I don't have the specs in front of me. It puts out over 400 lb-ft of torque pretty much off idle to 4000 rpm. makes around 350 horse around 5200 rpm. redlines around 7000. It's a 350 4 bolt main originally out of a 91 vette (center bolt valve covers) then rebuilt with a wild cam. It lopes nicely.:D getting the carb and timing set right is everything. Dyno time is worth every penny. you get real numbers and can see what changes do what. I have a 700R4 so not really a granny(3.06:1) I just mash it and let it do its thing.
    Best part is I went to the guy with a set of heads, rear main seal and tins. He built it for $1600. that included the dyno runs. That was 6-7 years ago. He just sold his speed shop september 1st.:mad:
  18. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    The SM465 only the beefiest tranny ever available in GM trucks. It is not an auto, it is a stick and is amazing. Do a search on SM465 swaps, there is alot of info out there on it.
  19. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    An Allison will eat a 465 for lunch. A 465 is not for everyone though.
    and...he's not a paying member, so no searching....except for google...
  20. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Get yer damn cover to Iowa! It's been paid for already. :deal:
