ht 383 engine swap flywheel question
Discussion in 'The Garage' started by AntAZBlaz, Jul 17, 2003.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    does anyone know if there will be a problem using my original fly wheel on this new engine. my 86 came with a 14 inch and the new engine came with a 12 3/4. being able to use the old one would mean that i could keep all of my old equipment and not have to modify anything.
    king
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you'll have to use the flywheel for a 400
  3. AntAZBlaz
    273
    Mesa AZ
    can you give me more detail i don't know to much about this subject. are you saying that it won't work?
    king
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    IIRC, there are internal and externally balanced flywheels.
    interal balance = every SBC i know of, except the 400
    External blanace = SBC 400
    you are using a SBC 400 crank in a 350 block, so your harmonic dampner and flywheel must be off a 400 since you are using a 400 crank. i assume you used the 5.565 rods and pistons for a bored .030 350 block, thus making a 383
    If you have an aftermarket crank (Scat, Eagle, etc.) then check your manufactuers guidelines.
  5. Gray Blaze
    Gray Blaze Registered Member
    Dec 31, 2002
    16
    Phoenix , Az.
    Call Kings Balancing service @623-934-3279 , they got um /forums/images/graemlins/k5.gif
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    is it an actual HT 383 by gm?? or one you built yourself??. The GM ones are also one piece seal, and the flywheels between the two piece and the one piece wont interchange either.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    My 383 is using the stock flywheel, GM PART # 14088761. This is a 168 tooth, for a one piece seal. I think '86 up used the same flywheel.
  8. AntAZBlaz
    273
    Mesa AZ
    Right now I have been through about 6 different starters and none of them have worked out correctly. And this is an actual gm performance parts 383.So all of the information for it can be found at.
    http://www.sallee-chevrolet.com/ChevySmallBlockV8s/HT_383.html
    Here is a picture of the rear of my 350.
    http://www.public.asu.edu/~antyk/rearoldeng0.JPG
    and here is the front and back picture of my flywheel.
    http://www.public.asu.edu/~antyk/flywheelback.JPG
    http://www.public.asu.edu/~antyk/flywheelfront.JPG
    By the way which side is considered the front and which is the back I’m not sure if matters or not.
    I called that shop Kings Balancing, and as soon as I mentioned that it was a crate engine they told me to call the Chevy place.
    Now I have called the Chevy place, in fact two dealerships but I don’t think they were really paying attention. Both of them said that I should just be able to swap the gears no problem. I just want to triple check that information before I waste more time working at something that is wrong.
    Is there any difference between GM PART # 14088761 and my flywheel any reason to buy that one?
    Thanks for the information
  9. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    The flywheel that came on your engine is a 153 tooth flywheel, and the one on mine is 168. The newer model 350's have the 168 tooth flywheel.
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If you look up the flexplate that comes with the HT383 (14088765) at the GM Performance Parts web site, you will see that it is a normal one piece rear seal 350 flywheel (153 tooth as noted above). This indicates that the HT383 is internally balanced, the same as a late model 350. You should be able to use your 168 tooth flexplate from your old 350 with no problem.
  11. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Anthony...get a hold of mosesburb...he is my best bud....and happens to be one hell of a parts man...he'll straighten out your problem!
    DW /forums/images/graemlins/usaflag.gif
  12. AntAZBlaz
    273
    Mesa AZ
    Everything has been worked out it was a pain to do but the old 14 flexplate is on the engine and the truck is running just a few things to work on and everything will finally be done.
    king
