Ht383 oil pressure?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AntAZBlaz, Feb 26, 2004.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    I was wondering if anyone else is running one of these and what kind of oil pressure you see out of it. My old 350 never went any where near the 60 mark on my oil pressure gauge but the 383 continuously starts up and runs around that pressure until hot.
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    mine runs right around 60 also.(383 )
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I know this doesn't pertain to your question but my original factory 350 that is still currently in my blazer runs just a hair under 60 PSI all the time. I have tested it with a mechanical guage and it is accurate. /forums/images/graemlins/thumb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My little 4.3L V6 with 148K on the clock fires up at about 60 PSI, even with Mobil 1 in the crank case. On really cold mornings it pegs the gauge at 80 PSI. /forums/images/graemlins/eek.gif But it's been like that since new, so I don't worry about it. /forums/images/graemlins/thumb.gif Once warmed up it runs in the 35-55 PSI zone, depending on RPM.
  5. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Sounds like a good oil pump to me...
    But definitely call the fellas at GMPP or better yet Scoggin-Dickey or Pace Chevrolet and run it by them to make sure every thing is on the up and up /forums/images/graemlins/waytogo.gif
  6. AntAZBlaz
    273
    Mesa AZ
    cool i just wanted to make sure others were experienceing the same thing.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    My 383 has a Z-28 oil pump and runs 60 psi.
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not running the HT 383, but my crate 350 runs 60 PSI or more at start and 45 or more when cruising. Idle when hot can get down to 35-40. I also have 30K or so on my motor though probably.
    Harley
  9. 1989k5
    1989k5 Registered Member
    Jun 10, 2003
    36
    near Lake Superior, Wisconsin
    You may have a high volume oil pump installed. irregardless, 60psi is fine, I'm not sure why you would worry about this amount of pressure. Someone may argue that you would pull all of the oil out of the pan which would cause the pump to run dry, but that seems unlikely. When I used to build motors more frequently than I do now, I alway installed a high volume pump which ran around 60psi all the time, never had trouble with them. Stroker motors like 383's don't require anymore oiling ability than other motors. I would think it is fine. Good Luck!! [ QUOTE ]
    [/ QUOTE ] RANGER: When you care enough to send the very best!!
  10. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    same here, a 383 with 60 plus, one thing to think of is are you sucking your oil pan dry? do you run a external oil cooler or a deep sump oil pan? some thing to think about maybe?
  11. J.R.
    J.R. Guest
    i thought they came with high pressure pumps and not high volume...
