htdro assist
Discussion in 'The Garage' started by pennsylvaniaboy, Feb 1, 2007.
tap the box or steering caps?
  1. tap the box
    12 vote(s)
    31.6%
  2. tap the steering caps
    20 vote(s)
    52.6%
  3. i'm nekkid woo hoo
    6 vote(s)
    15.8%
Multiple votes are allowed.
  1. pennsylvaniaboy
    pennsylvaniaboy 1/2 ton status
    Jan 28, 2006
    844
    pennsylvania, 15537
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I chose caps over the box to ensure my hoses where out of the way and would not be contacted with the tire. I only run 4" lift and have plans to move my axle forward and run 42s.
    It really comes down to personal preferece, if you tap the box it does not cost you anything extra if you do it yourself. I paid for the end cap and tapped my topcap myself.
    Ira
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I did the same as sandawg. One reason being that if the steering box takes a dump, I can simply swap the caps over vs. having to retap the new box. In the event it happened out on the boonies somewhere, at night, it would be a lot less hassle to swap the caps over and install the box without having to mess with the taps. Also, I might be able to use my old one as a core at the auto parts if I buy new. :dunno: I doubt they would take it with taps in it, but you my be able to slip it by them.
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Thats exactly why to go with the caps, I agree. Also easier to install!
  5. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    when i returned my box capless to vatozone they didnt say anything, i dont even think most of those guys know what they are looking at. when you tap the box itself i would imagine you get a ton of metal chavings inside your box then the whole power steering system... no bueno. and the caps keep the lines out of the tires and whatever else passes through your wheel wells
  6. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    wouldnt tapping the top box put shaving in there too
  7. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    That's what he's saying. That tapping the box has the potential for leaving shavings inside afterwards, and that the tapped caps help to keep the lines pointed away from the tires, where they could get snagged.
  8. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I don't have any experience with steering boxes but if I was to drill and tap the top cap, would I be able to unbolt it from the box? This way, shavings won't get into the box during the drilling process....
    Hope I'm right and makes sense...
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yup, this is one of the advantages of doing the cap.
  10. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    yes, the top cap unbolts and then unthreads from a stud in there where you can throw it in a vice and tap it and replace it clean
  11. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You are supposed to remove the top cap when you drill and tap it.
  12. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    so if you do caps no chance of getting shavings. im also new to steering so how does tappin the caps/box get you hydro steering versus say an orbital valve? just curious
  13. readymix
    May 30, 2004
    6,706
    26
    That would be Hyd-Assist vs. full hydro
  14. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    yeh i kno that but what im asking is how does putting two hols in your box and plumbing lines to a cylinder automaticly give you hydro assist
  15. readymix
    May 30, 2004
    6,706
    26
    Fluid flow is routed from the box to the ram.
    The ram either compresses or extends depending on the direction of fluid flow.
  16. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    guess you would have to understand the inner working of the steering box
  17. pennsylvaniaboy
    Jan 28, 2006
    844
    pennsylvania, 15537
    so guys does it do any good to do hydro when i dont have crossover.
  18. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    when you have your driver side tire drooping you wont be able to steer, it will be in a bind, and having hydro assist would probably do more damage then good
  19. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I hope that was meant nicer than it sounded to me. The answer is that the fluid flows inside the steering box according to the direction you turn the wheel. As you turn right, for example, the pressure is located at the top side of the box. Running a line from this area of pressure to one side of a hydraulic ram enables the excess pressure and fluil to escape from the box, and power the ram. I have heard of a guy that used the steering box as an orbital valve in a full hydro system. When the wheel was turned, he just had to wait for the tires to catch up. Crappy IMO but it did work.
    Tapping the caps is a better solution IMO. If you have a box explode on you, you can just move the caps to the next one.(personal experience). Also if you tap the box itself, and you are a hair off, you ruin the box. Someone stated earlier about removing the top cap and removing the sector shaft from it. I did not remove the sector shaft from my top cap when I tapped it. I did not want to mess with getting the preload back in the correct position, so I left it together. As stated above, the line routing is improved with the cap method.
  20. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
