HTML/Internet posting/retrieving help
Discussion in 'The Lounge' started by Leadfoot, Feb 12, 2003.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I created a site in front page and put it on the web through www.hostserve.com
    The site is www.MATPA.org. It is just thrown up there for now (even the email address is wrong.....shoud be Balise@MATPA.org instead of Balise@MATP.org). My question is how to I remove a page from the domain. I can update and change a page (i.e. index.html), but if I want to pull a page off the server (i.e. delete it), how do I do that????
    Any help would be appreciated
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    If you can't delete it, change it.
    create a blank document and call it index.htm and update the existing one.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK, I'm a dreamweaver user but let me see if I can walk you through it.
    1. make a folder on your computer call it something like 'matpa'
    2. Open frontpage, click file, OPEN WEB... Direct the open window to the MATPA folder on your computer. It should say frontpage needs to add things to this folder to make hyperlinks, blau blau blau.... click OK.
    3. File, New Page...
    4. Type 'this is the opening page for MATPA.org, please check back later'
    5. File, Save As, index (you should be in the MATPA folder still)
    Now you should have a folder list that shows index.html next to the page you designed. Right click index.html and hit publish.( publish ) Or go to File, Publish Web, and complete the info for your site (i.e. the web address, login, password, host directories, etc.)
    Hope this helps.
    J
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Do you have ftp access to the site?
    Your host should have given you the login info for ftp access.
    ftp://[ftp sitename], login if/when prompted, find z file, delete it.
    Or, go to a command prompt, type "FTP" and hit enter
    then type thefollowing commands and hit enter after each:
    open [ftp sitename]
    user
    [username when prompted] [password when prompted]
    "ls" or "dir" to get a list of files in the folder
    delete [filename]
    If you go command line, you may or may not have to do some directory navigation, which can be a little confusing in ftp, since the prompt never changes. Personally, I prefer command-line over gui (ftp programs). Command line gives you more control, gui just looks perty and gives you some basic funkshunality.
    I'm sure that's just vague enough to confuse anyone! Ask if so!
  5. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Try logging in here: ftp://www.MATPA.org/ , find it, and delete it.
    I use WS_FTP most of the time. I've been using it for over 5 years now and prefer it to anything else.
