Hub Leak
Discussion in 'The Garage' started by TXsizeK5, Apr 20, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Tiny drops of oil seep out when i drive out of the hubs in the 14bff it happened before so i RTV'd it. And it stilld oes it a bit, I duno if i tightened the bolts enuf, i know they are super tight, should i go ahead and tighten them more?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I think Randys ring and pinion has a torque spec sheet in one of his tech articles check there for tightness.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Nevermind I found it 115 ft/lbs on the axle flange's.
    -Brian
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    thanks... i need to get me a torque wrnech!
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    No problem. /forums/images/graemlins/thumb.gif
    -Brian
  6. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    make sure both surfaces are clean and your fingers are clean before you apply the rtv. It should work fine as long as their isn't gearlube on the surfaces!!
