Hub not locking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Dec 24, 2001.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Hey all:
    Merry Christmas. Here is a rookie question for you. I have an 86' K5 and my Warn Hubs aren't locking. Axles and drive train are spinning but tires aren't. What did I do wrong when I re-installed the mechanism? What do I do to trouble shoot where my problem is?
    Thanks,
    Chris
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    How do you know the axles and drive shaft are spinning. In the front I assume? It sounds like you're missing some internals on the hubs, or they're broken, or the splines are stripped on the locking hub or even wheel hub. Did you buy it recently?
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Yep, it's the front. I was in the snow yesterday and was sliding so I had some buddies get out and check. Hmmm. Thank you for the input!
    Chris
  4. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    are they manual or auto hubs?
    <font color=red>Let me at it I can break it</font color=red>
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Oh yeah. I bought the truck about two years ago and the hubs worked fine. Over the summer I went in a replaced the bearing but I don't know if I put back in properly.
    Thanks again
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    They're manual locking. I would appreciate it if you did!! I need to get back to the snow next week! I almost had to buy chains for my 33's! $100 on the mountain.
  7. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    I would say jack the truck up and see if it is one or both by manually locking one at a time and then both to see if one hub is bad or you just didn't get something together right on one of the hubs. If they are bad a new set is only $60 for both hubs
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Okay. Thanks! I'll let you know what happens.
    Chris
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To troubleshoot: Jack up the front and lock the hubs. As you rotate the wheel, the axle shaft on that side should rotate with it. Just watch the u-joint at the end of the axle housing to see if things are moving. Unless there's a locker in the front differential, then having just one hub that isn't locking will keep the front end from pulling at all. [​IMG]
    When you had things apart, did you happen to pack the hub housing full of grease? This is a common first timer's mistake. The grease will prevent the hub from sliding into position for locking.
  10. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I sure did pack that with grease. I knew I should have never bought that stupid Chilton! How much grease should I put? I think that is what my problem is.
    Thanks!!
    Chris
  11. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Just enough to coat the surfaces.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    All you need is just a VERY light coating of grease on the splines, to allow them to slide in and out as you lock and unlock the hubs. Clean that out and your hubs should lock just fine. [​IMG]
  13. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks!!!
  14. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Be sure to post some pics of you throwing huge rooster tails of snow from all 4 wheels after you have the hubs working again! [​IMG]
  15. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Grease the hubs? I've never greased my hubs. I always heard it was a big no no! Course it's real dry out here so rust and mud and crud isn't a big problem.
    Jim
  16. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    It worked. I'm ready to go! Just wanted to say thanks. I'll try to take some flicks this week end!
    Merry X-mas...
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sweet! Glad to hear it was an easy fix!
