Hub Nut Removal Tricks
Discussion in 'The Garage' started by Cricket, Nov 19, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Anyone have a trick for getting the hub nut off when the axle is sitting on jackstands? The nut is on tight on the axle wants to spin right off the stands when I try to loosen the nut. Having the wife sit on the axle didn't help much and she thinks I'm crazy to begin with. :doah:
    The nut socket wants to move from side to side too so it's a bit frustrating. Maybe I need an impact? Someone has to have a trick to getting this s.o.b. off of there.
    :1zhelp:
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Definitely one of those times when air tools are your friend. :rolleyes: :wink1:
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Impact, or stick a screwdriver in the rotor fins and let it hit the caliper. That should hold everything still. Good luck.
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Nothing like an impact. Good reason to get an air compressor and tools :D
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I just let the jackstands down a bit so when it started to spin around the pinion hit the ground that way you're using the weight of the axle against it self...worked for me :confused: Maybe do somthign redneck like chain it to something in a way so it won't rotate and use a big cheater bar? Can't be THAT difficult ;) :D
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Hey James, I can tell you how THIS old redneck does it on D70s:
    Step one; go buy 2 new hub nuts
    Step two; go buy a GOOD cold chisel bout 18 inches long
    Step three; use the cold chisel and a 3 pound hammer to turn the old nuts off
    Step four; throw away old nuts
    Good Luck Buddy!!!!!
  7. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Got it off and got the axle disassembled. Thanks guys for the advice, in the end I just set it on the floor.
    The only nut I have not been able to break loose is the pinion. I have a feeling I'll be lifting it onto the bench vise.
    Unless someone has a simple removal method for the pinion? Ha, the search function does have a purpose but my brain doesn't. :D
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'd bust those things loose before you take the wheels off next time.
  9. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I bought it loose - ie. no wheels/not mounted. Needed it for the 8 lug outers. If it had been on my truck things would have taken a different direction.
    The pipe wrench trick worked great on the pinion, thanks dudes.
