hub Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Dec 11, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    my auto hubs have 5 bolts, and the manual replacements have 6...what does that spell?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    No problem. The bolts screw into the inner part of the hub, which you are also changing when you install the new hubs. /forums/images/graemlins/thumb.gif
  3. tecton
    Dec 1, 2002
    1,553
    WV
    nice
    ive read every topic on this board on the switch...is it as easy as it seems?
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if you've ever had a hub off, it might take 45 minutes, TOPS...
  5. tecton
    Dec 1, 2002
    1,553
    WV
    never had one off
    do you have to mess with the brakes?
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You don't even have to jack the truck up. /forums/images/graemlins/thumb.gif Remove the old hub and innards, install new hub and innards. /forums/images/graemlins/cool.gif
  7. tecton
    Dec 1, 2002
    1,553
    WV
    thought you had to take off the wheel and all that crap?
    just unscrew old one, pull really hard and put the new one in?
  8. Confedneck
    Nov 1, 2002
    5,236
    not even pull really hard...its an easy, straightforward swap..
  9. tecton
    Dec 1, 2002
    1,553
    WV
    ok so i dont get how it stays inside...if the end part screws onto the other end...what does that connect to?
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There's a snapring on the axleshaft. Take that off and the innards slide right out. (On manual hubs, there's also a large external ring that fits in a groove on the inside of the hub...I don't recall if the auto's have that, but it can be a b!tch to get out sometimes.)
  11. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here is a pretty good post on this
  12. tecton
    Dec 1, 2002
    1,553
    WV
    i rekkon ill give it a shot...hey, if it doesnt work, i can come here and b*tch about it, lol
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There will be a small snap ring on the end of the shaft that you remove first. After that, you'll see two little things sticking out that are attached to the inner snap ring. Squeeze them together with pliers and use one of the screws to remove them. Pitch those auto hubs, pop the manual in and install snap rings, install outer hub with dial, and you're done. Whole job an be done in 30 minutes or less if you're experienced, double that if you're not totally sure what is going on...but it'll only take a few minutes to figure out. /forums/images/graemlins/thumb.gif
  14. tecton
    Dec 1, 2002
    1,553
    WV
    will there be room to take these snap rings out with the wheel still on?
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Pssst, we already told ya that you do NOT have to jack up the truck, which should imply that you also don't have to remove the wheels. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  16. tecton
    Dec 1, 2002
    1,553
    WV
    one person said that, then 3 people said nothing
    just making sure /forums/images/graemlins/ears.gif
  17. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Hubs should have instructions with them....they worked for me. I did mine for the first time and it took about prolly 45 min's. It's easy!!! /forums/images/graemlins/thumb.gif
  18. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Putting them back on can be trying if the axle gets pushed back towards the pumpkin. If the snap ring won't go back on the axle just reach around the tire and push the axle u-joint towards the hub. The is like 1/16" of play in the axle. I jammed a large screwdriver in the knuckle to hold the axle outboard while I put on the snapring. If you do it this way, remember to pull the screwdriver out before you take your test drive. /forums/images/graemlins/thumb.gif
  19. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    like the other guys said you dont gatta even take the wheel of but even if you did..is it really that big a deal? /forums/images/graemlins/rotfl.gif
    im just playin /forums/images/graemlins/thumb.gif
