Hub Replacement Question .?.?
Discussion in 'The Garage' started by larryslamps, Nov 21, 2006.
  1. larryslamps
    larryslamps Registered Member
    Nov 10, 2006
    17
    Kentucky
    I have an '87 K5 (64K miles) with the automatic locking hubs. I have heard
    alot about them not being that durable. I don't do any extreme wheeling, not
    that I don't want to, just not alot of time, just mud and snow driving in the winter and spring. This is my daily driver also. I am not a mechanic, but like most anything if I can take it apart or remove it , I can put it back together with ease. 1. Are manual locking hubs something I should look into &
    2. What does replacing the automatic with manual involve? Do I have to remove the tire? Will this change the way I shift into 4 wheel drive? (i.e. can I just shift into 4 high and lock the hubs?) Thanks for the help.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you do not need to take the tires off to change the locking hubs. You will need to get out of the truck to engage them when you want 4wd.
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    What he said. Also, the selectable hubs are stronger. If you do mud youll probably want them anyways because mud clogs up the internals of auto hubs and makes them not work.
    -Harrison
  4. larryslamps
    Nov 10, 2006
    17
    Kentucky
    Are there particular models specific for the 87 k5? Would like
    to see if I could buy some on eBay if cheaper.
  5. larryslamps
    Nov 10, 2006
    17
    Kentucky
    Also, what brand would you reccomend? MM, warn, ?
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    most everyone is going to recommend warn premium's, however, I have not had a problem with warn standard or MM hubs
  7. dyeager535
    26,980
    If you've got wrecking yards around you, I've had good luck with the Spicers that were stock earlier on these trucks. And they were cheap.
  8. 87BrnRsd
    Apr 21, 2003
    2,457
    I second the warn premium's. I grenaded a warn standard in no time once i installed a front locker. That sucker blew up before could really give it hell.:D
    -Harrison
  9. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Checkout jeeperz creeperz ebay store.I got a set of MM premiums for $60.They are in Michigan.:D
  10. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    OK, I gotta ask: Does anyone know FOR SURE (not "I think...") where the MM hubs are made?
