Hub & Rotor Removal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by conv76jimmy, Sep 25, 2001.
  1. conv76jimmy
    conv76jimmy 1/2 ton status
    Feb 18, 2000
    281
    Yay Area, CA
    I was trying to change my Rotors on my 81 Chevy Blazer with manual locking Hubs, I got as far as removing the Locking & Unlocking mechanism then after that I didn't know what to do. I am used to working on my 2wd so this looked alot different. So my question is what do i need to do to get the Hub off, After I removed it all I could see was a Gear and nothing else. Any help would be Greatly Appreciated!!!
    2-wheel'n all the way!!!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You need a pair of snap ring pliers, and a spindle nut socket (about 15 bucks or so at the auto parts) There's a snap ring that holds the gear in place, once it's out, you can pull the gear, and you'll be looking right at the spindle nuts - from there on, it's pretty much the same as a 2wd, but bigger.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. conv76jimmy
    Feb 18, 2000
    281
    Yay Area, CA
    Sorry to sound so dumb, But where would this snap ring be at. Is it right in front of the Gear?
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Yeah, usually caked with grease so you can't see it very well.
  5. conv76jimmy
    Feb 18, 2000
    281
    Yay Area, CA
    Thanks!!!!
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, there is a big lock ring and a little snap ring. I have found that a scribe works best for getting the large lock ring out. A pair of needle nose pliers will come in handy too.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
