hub seal leaking on 14bff
Discussion in 'The Garage' started by 85mudblazin, Feb 10, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    well after I installed my new hub seals they are leaking, I pushed them in to where the seal is level with the top of the hub, should I buy new seals?? Push them in further??
    -Chris
  2. sweetk30
    Nov 1, 2004
    25,534
    531
    horseheads , ny 14845
    possible bent seal when installing drum or rotor assbly . from the weight of units its hard to not set on spindel and bend them.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You put them in correctly, the spring could have come off.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    hhmm maybe ill just get some new seals and give it another try. :confused:
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well put some grease on the springs before you go pounding them in.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok thanks. ill be more careful this time :)
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If you installed the seals properly and it still leaks, here are some things to look at that could cause leaks even with perfect seal installation:
    are your wheel bearings loose?
    what do your spindles look like? are they rough/corroded where the seal rides? are they grooved where the seal rides?
    If they are grooved, you can fix it with a redi-sleeve Chicago Rawhide p/n 99282.
    Also, make sure your axle vent is not stopped up. A buildup of pressure could also cause the leak.
