Hub seal.. ugghhh
Discussion in 'The Garage' started by 78Suburban, Oct 2, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Well guys, when I did the disk swap I was told to replace the hub seals on my 14ff, so I bought 2 federal-mogul 2081 hub seals. It was very hard to get the seal out of the hub, I used punches, screwdrivers, vice grips, and a bit of explicit language. I drove the seal in evenly and decided it wasn't worth the trouble to replace the other one...
    This morning I looked and one of my rear tires was covered in gear oil.. got to looking and the hub seal THAT I REPLACED is leaking... really wish I had left it alone.. I may have scarred up the hub so that the seal doesn't seat properly.. guess I need to find a new hub or what?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    take it back apart, & see if u scared it, if u did & it isn't bad smeer silicone on it & install a new seal. maybe not the right way but it does work. i have to do that on our dump trucks, dad is too cheap to replace the hubs.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    487
    New Hampshire
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm almost positive I scarred it thinking back.. the RVT fill in sounds like a good idea..
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yep, if your hub is scarred, I'd just hammer it in with a dab of RTV.
  6. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Might be worth the $$ to get one of these.
  8. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Ah yes, the speedi sleeve. I forgot to ask him what the spindle's seal surface looked like. But since it didn't leak earlier...
    Hey James, you didn't by chance install the seal backwards did you? It's pretty easy to do, I've seen seasoned vets do that before. If it goes in backwards, then it's real easy for the spindle to rip the spring out of the seal when you slide the hub on, then you won't be getting much of a seal. Seen it happen several times.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    nah, I double and triple checked against the other hub, definitely not backwards...
    I'm thinking I really buggered that hub up, I mean, I got downright violent trying to get the old seal out.. I recal definite scarring, but didn't deem it relavent at the time..
  10. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, that doesn't sound good. Maybe try the old wheel and crowbar trick next time.
