Hub Socket
Discussion in 'The Garage' started by Stormin, May 14, 2005.
  1. Stormin
    Stormin Registered Member
    Apr 25, 2005
    35
    Redmond WA
    I'm just curious how many of you out there use one of those big hub sockets on the spindle nuts inside the hub and who uses the hammer and screwdriver method. I've never used the socket before and have never had a problem. Any horror stories out there that stem from using the farmer method?
  2. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I use a socket, how do set your preload with a screwdriver and hammer properly?
  3. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Socket, I own two, one for work, one for home. I just bought one for my 14bff too.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have done it both ways, but i prefer to use the socket
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    How would a hammer and punch work on a fron hub? That nut is a ways in there.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I bought the socket , after years of being slightly stupid , I now try have what I need beforehand so I have the least trouble possible :D
  7. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I remember seeing that NAPA carries these sockets. Does anyone have the part numbers for the D60 and 14FF ones? Thanks.
  8. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The proper socket is only $20 at checker. Get the right tool.
  9. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    Never even considered using anything but the socket. Tough to get the torq right with a hammer. ;)
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I use the socket. You can also put the nuts from a 60 on a 14FF the spindles are the same size. I had the od of my socket turned down at work so I only have to have one socket to do both front and rear.
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That should be left to emergencies. I like to have my wheel bearings properly torqued, the thought of losing a wheel on the freeway is pretty scary.
  12. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    the peace of mind of knowing it is properly torqued is well worth the $ for the socket in my case
  13. j250trxr
    j250trxr Registered Member
    Mar 19, 2005
    57
    mn
    i also use the socket
  14. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Diggin' up old threads and still can't find the answer. Does anyone know the part numbers or will the parts guy be able to pull these sockets by what axle they work on? Maybe a size of socket would be handy?
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    See if you can find one of these:
    http://www.lislecorp.com/tool_detail.cfm?detail=383
    Then you're all set for the 4-pin Dana 44 and GM 10-bolt, as well as most 14 bolt rears. :cool1:
    They show 2 sockets in the photo, but I'm fairly certain that it's actually a single socket. At least that's how the one I bought off of a Mac tools truck is made.
  16. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    the only place here that had that socket wanted 80$ for it...no way :mad:
    I'll try make my own....
  17. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i have went both ends of the spectrum, i machined my own socket for my 14ff which worked great, but its not heat treated so i dont know how long it will last, and i also bought a snapon socket so i had a "good" one. the one i made works the same as the snapon does.
  18. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i bought the socket.i got my moneys worth out of it.used it on my '79furd,76,74,85k-5s,82k-10 and this weekend on my 80dog ram.
  19. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Thanks, got one ordered, Hope it works :crazy:
  20. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Ouch!!! :eek1:
