Hubs are Hot is this normal?
Discussion in 'The Garage' started by dayno, Sep 27, 2004.
  1. dayno
    dayno Registered Member
    Sep 25, 2004
    6
    I test drove my 1977 K5 after puting the carrier back in and putting the hubs etc back together....the hubs seemed pretty warm when I was putting the dust covers back on with sealant after the test drive....Im thinking this is normal since they pick up heat from the disc brakes but wanted to check here about it....thanks in advance for any help....Dayne
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Is it a 14BFF? Did you put some gear oil in the hubs for the bearings to run in till the hubs fill from the center section?
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would guess he is talking about the front D44, the hubs should be farely warm from heat off of the rotors and the bearings inside generating some heat.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you have been using the brakes hard they will be hot. I normally check mine after driving on the hwy for a while. They are always cool except for the time that I had a bearing out. If you are using the brakes hard the can sometimes be too hot to touch.
