Hubs interchangeable from 1/2 ton to 3/4 ton?
Discussion in 'The Garage' started by stallion85, Sep 14, 2005.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hubs interchangeable from 1/2 ton to 3/4 ton? Is this true? I got a line on a whole D44 I am going to grab for some spare parts for Moab and was wondering if I could use the hubs too.
    Thanks :wink1:
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the lockouts will, but the bearing hub will not as the 1/2 ton are 6 lug and the 3/4 ton ... blah blah
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    There are two versions, big bearing and small bearing. Not sure if the spindles are different as well on those models, but they may be.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    small bearing hub = small bearing spindle
    large bearing hub = large bearing spindle
    I'm not sure if there is any rule on how to tell what size bearings the spindle has without disassembling it, but I have noticed that all of the ~pre-76 D44's with flat top knuckles I have taken apart came with the small bearing spindles, and the non-flat top knuckle D44's and all 10 bolts had the large bearing spindles. This is just what I have noticed from the dozen or so I have owned, so it may mean nothing at all.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It has flat tops on it and I believe it is from a 75. Hmmm, oh well.....at least the shafts will do me some good. I could probably sell those flat tops for and just buy some hubs :rolleyes:
  6. divorced
    Jul 20, 2004
    5,115
    I would take it apart and check it for sure, GM did some strange things back then. If you can't tell the difference, just post up a pic of the spindle.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That has been my experience as well. Here is a pic of the 2 types of spindles for reference. :D
    The large one is on the right. :D :D :D
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    took me a minute to see the difference, but I see it now.....thanks Beast :wink1:
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    ...if they are both internal spline.
