hubs not disengaging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Feb 12, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    wats going on? its on a D60 front and they're not disengaging when i turn em to free. It doesnt matter that much, this is mainly a trailer queen, but i dont like hopping around turns when i do drive it.
    phill
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    you need to take them off and clean them up the springs are either broken or stuck in old grease had the same problem the other week
    4x4k20
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    thanks, will do when i have the time.
    phill
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I have seen where people have taken the hubs apart to clean, and then put the springs back in AFTER the clutch ring instead of before. The hub goes on fine, but the spring holds the clutch ring in (engaged) ALL the time nomatter what the position of the dial is. The spring is designed to go in first to force the clutch ring back out when the dial is turned to "free". I have also seen where people use too much grease and it keeps the hub from disengaging. The hub assembly is meant to be lubricated, but that is by LIGHTLY greasing.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
