hubs, whats the diff...?
Discussion in 'The Garage' started by TXsizeK5, Feb 25, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    EDITED:****whats the diff between hubs up to 76 and then 77-87? There are two diff ones on 4wheel parts andboth are diff prices , can anyone tell em?****
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: got my front axle.. how is this--spicer hubs?
    There are corp. 10 bolt 8 luggers, no clue about the hubs
    Dan /forums/images/graemlins/burb.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    there was a post about hubs, and those spicers were brought up, i cant remember who, But they said they are pretty srong, but kinda a PIA to work on......
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What type of hub is it.
    There are 2 types:
    External (held in by 8 bolts that like to work there way loose) and internal.
    Internals came on 77 and newer axles (D44 or 10B)
    I have the internals on mine. I have yet to break them but had some problems with them engaging when I packed them with too much grease /forums/images/graemlins/rolleyes.gif
    They work the opposit of a warn type hub. When you lock them a the spring trys to ingage them and when the teeth line up they lock (this is why I had problems...too much grease in the teeth for the spring to overcome).
    When you unlock them (1/4 turn) you are fighting against the teeth to disengage them. Warns disengage by spring pressure when they free up (not when you turn the dial). Sometimes I can't turn the dial if the drivetrain is bound up (same with the t-case). If I shift into 2wd while the truck is rolling I have a easy time with the t-case and the hubs then unlock easy as well. If I stop the truck with it in 4wd I often cant move the t-case lever or unlock the hubs!
    Overall I like them. The price was right (they came on my truck and another pair on my 3/4-ton D44) and I have had no durability issues with them at all.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Now I am totally confused, I have a d44 1/2 ton off a 72 and my 3/4 ton 10 bolt, the hubs look to be the same except ones black and ones chrome. Do you have pics? Also are all 10 bolt front axles the same or did the switch anything up on them sometime?
  6. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    its an internal hub. i'm perty sure its a 10 bolt but i'm not so sure. i'll look up the years for them. good buy btw. lol. later.
    jacob
  7. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Re: got my axle...hubs, whats the diff...?
    Its been brought up a few times, at least once last week. Triaged nailed it, so I won't add anything but to say I like mine.
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have a stamped 74 d44 and it has the internal hubs, with the larger wheel bearings...
    I'm a bit confused myself....the spindles and hubs and bearings are way diff from my 84 10 bolt..
  9. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Ok, I have the axle now...and its internal style. Does the pre 76 mean its external? and 77-87 mean internal?
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have another question. For the 10 bolt fronts, are all the parts, wheel bearings, ball joints, etc. the same from 77 -90?
  11. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Yes, unless someone swapped outers.
  12. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    For blazer yes, but trucks changed to IFS in 88. I got this front out of a truck so it has to be pre 87... looking at tbhe grille it looks pre 85 i think, not sure /forums/images/graemlins/confused.gif
  13. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Is there a thick spacer that is bolted to the wheel hub? When i got my '73 axles, the D44 had what appeared to be internal spicer hubs. There was actually a 1"-2" spacer that the locking hub actually sat in. To use the new external locking hubs, all i had to do was remove the spicers and that spacer. Take a look at that hub, and see if there is one there.
  14. nofeartruckin00
    Oct 5, 2001
    798
    Like Triaged said, the one on the left is the 1st design (bolted to hub), and the one on the right is the 2nd design (held in place with the internal lock ring)
