Hubs won't stay locked.
Discussion in 'The Garage' started by 84mudmachine, Jan 6, 2005.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    My front hubs want to unlock when I go in reverse. They are the stock auto hubs, any ideas to what causes this?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Time to swap to manual hubs. Trust me...... Autos start doing this after a while or will disengage when you need them on the trail....
    Go get yourself some Warn Premiums.. :thumb:
  3. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Qeustion
    Manual sound good to me, are they an easy swap?
  4. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    Milemarker
    How are the milemarker hubs. I read a comparison between warn the milemarker, and they both seem to be well made.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I agree you need to get new hubs , because the stock ones always fail . The unlocking is normal though when not in 4wd . I believe the original procedure when done wheeling is to put the truck in 2wd and drive backwards 10 feet to make sure its unlocked :k5: :k5:
    I reccomend lifetime warranty premium Warns :D
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have had both MM and Warn. The bad thing is I didn't have the MM's very long and sold the truck so I cant give you good info on them...
    But I have had a few sets of the Warn Prems and no problem.
  7. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    once my Superwinch manuals give, i'll be switchin to Warn Prem's also! didn't have the loot for them at the time my autos blew out....And yes..very easy to install...1/4 or 1/8'th allen wrench and some needle nose to remove the snap ring and about 45 mins of your time...and ur done!
  8. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I'll have to go against the grain and not recomend the Warn "Premium" hubs...
    I've run the standard $60.00 Warn hubs for years on many different trucks and have been happy with them. When I rebuilt/geared my front axle I decided to spring for the "premium" hubs. I found that the only part of the premium hubs that is any stronger than their standard hub is the dial. I've also found that the standard hubs seal out water and mud better than the premium hubs. The design of the premium hubs is such that when the hub is in the "lock" position the seating force of the dial against the O-ring is reduced considerably, letting water leak around the dial. I also think the engagment spring on the standar hub is better than the premium.
    I've gone back to running the standard Warn hubs and have been happy:)
