Hummer 12-bolt valve stems?
Discussion in 'The Garage' started by grimjaw, Mar 23, 2007.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I just got a set of hummer 12-bolts that I am currently sandblasting. 3 of the 4 rims do not have the valve stems in them. These rims use the funny valve stems like the picture below.
    The odd balls do not use a round hole just a little slot. The only place I found them is a 'Hummer' store and they want $36 each! Thats stupid.
    Has anyone found a cheap (reasonable) source for these? Or should I just drill them out and use TR412 valve stems?
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Best solution all the way around.
  3. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    I was wondering the same thing for the ones I just got. I have 3 rims out of 5 that need them.:D
    Z
  4. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    TR412 valve stems are less than a inch long and made of rubber. THey are mainly use in ATV wheels. I think they would work well, if I can not find the mil spec ones cheap.
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I gave up on the Mil-spec valve stems, way too pricey. I bought a bag of TR412 valve stems off ebay. I had to get 100 but they were less than 1 mil-spec valve stem. I will use a 1/2" stepped drill bit and bore a new hole and use these.
    22mm length
    If one goes bad I have a 'few' spare.;)
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i need some too! ive got 5 rims and most of them need valve stems.
