Hummer Rims on a K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Dec 12, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Ok I know they will bolt up (I have 8 lug) but I also know they have some weird backspacing will they work?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. Ruthiford
    Ruthiford Registered Member
    Jun 25, 2001
    37
    Denver Co
    you can use 1"-1.5" wheel spacers and the will Thats what im gona do I payed 25bucks a piece for mine! My friends and I did some testing with them we pulled the valve stem core's(zero air pressure) and went to rasin He// with the truck(70'sinternational crew cab Dana 70 front /Rockwell rear 4.88 gears 4 speed ) we could not get the tire to spin on the rim nor the bead to come off!! Just dont run on the run flat for to long oryour tire will be toast! O yea there are 2 different designs one has around 8 studs to hond the rim togetherW/an aluimnum runflat the other has 12 bolts with a2 piece rubber R F
  3. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    I think the backspacing might be too much. They work well with narrow rigs with full width axles. I have thought about using them myself, but Stephen at ORD talked me out of it. He knows more about them, so maybe post this on his forum. Jon
    Blazin' Trails ORD Style
  4. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Hm. I was told that the runflats were actually magnesium, not aluminum.
    Runnin' them (w/ the 8 studs) on my truck, no prob's, though one tire does has a steady but slow leak.
    --Rob
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Any pics of your K5 witht he Hummer rims Ryeguy?
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  6. Cavalry
    Oct 1, 2000
    978
    I have always heard stories of people running on flats with magnesium wheels and them catching fire (magnesium burns feircely once you get it started its very hard to put out and burns at thousands degrees) I'm not saying anyone is wrong just sounds like a bad idea to me. The ones I have always run had the rubber runflat
    Luke
    84 K5
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    From everything I've heard (do a search) the Hummer wheels have such huge backspacing that they hit all over the place and are pretty much useless. The only way to use them is to provide a 4" (or so) spacer. I would love to be wrong since they are so cheap...
    I have often wondered if they would work on a D60 (and C14) from wide axle dually.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  8. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    there are 5 models of these rims but the only two run flats are a two piece magnisum and a solid rubber piece. 'the spacers will work for the rims and some setups have no problem, the backspacing is huge so the rim can clear the geared hub. There a great rim if you can get them to clear.
