Hummer rims w/original centers and spacers
Discussion in 'The Garage' started by KRAZIE87K5, Oct 13, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I need help from you guys. I'm looking to run my hummers with the original centers in them, and just run spacers to make up the difference in the rear, and HOPEFULLY find a set of Ford DRW 60 bearing hubs to take care of it on the front end.
    The question is... what size spacer do I need in the rear to get the proper WMS to WMS distance?
    Thanks for the help!
    -Dan
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Just out of curiousity, why do you wanna run the Ford bearing hubs? For the dual piston calipers?
    I may know where you can get the bearing hubs if you cant find any.
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Well... I've already got the Ford outers on my 60, and I really didn't want to spend the money to convert over to Chevy stuff. I figure that I'm going to 35 spline, so nothing should break then. *knocks on wood* Yes, I have the dual piston calipers on there too... and I kinda like them!
    If you can find a set of Ford DRW front hubs... tell me! I've got money in paypal RIGHT NOW for a set. Let me know what you find!
    -Dan
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I'll be in touch/forums/images/graemlins/thumb.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just an FYI comment...
    The Ford knucks are weaker, just talk to Matt (NoRulz) who broke 4(?) with stock Ford PS, no hydraulic, and no high steer. Also, the tire rod arms are shorter making it hard to build a heavy tie rod in the low steer position, 1.5" OD is the max and will hit the cover (as we found when I built Matts tie rod, we couldn't sleeve it up to 1.75" like mine). He finally switched to GM knucks (DaedenBear) on his Ford and he has since added hydro assist.
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I just ordered the alum for these, I'll get them made up and keep everyone posted...
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Tony, any idea on price for these?
  8. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Dan, dump the Ford crap and convert to GM.
    BTW, did you get a chance to pull that axle shaft setup out of your rig yet?
  9. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    ...and if you are going 35 spline the Chevy/Dodge knuckles, spindles, ect take them w/o mods. The Fords need mods to the stub shaft.
