hummer rims
Discussion in 'The Garage' started by shaun, Apr 1, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Is any one else running hummer rims. Stock ones not the stazworks. Just curious what the look like mounted and how to do it. Is it hard????? Pics please if you have them /forums/images/graemlins/thinking.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    i have a set on my dually D60 front.click on the pics link in my sig. below.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    check out chvyhs's BLING posts in the burb forum, he is running recentered hummer rims /forums/images/graemlins/thumb.gif
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Mine are just like Chvyhs but in the 12 bolt style. You can see all the pics of the rims inside and out in my pics link at the bottom.
  5. shaun
    Apr 22, 2003
    745
    What is this recentering? How do you do this? Do you have to? What does it do? Any more pics? I am getting more and more psyched about these.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    how much was it to recenter those?
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I take it you went ahead and got a set from eric?
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Where did you get them recentered at?
  9. Esteban86K5
    3,712
    Bakersfield, CA
    O.K. I found an old card I had from them.
    The place is
    Taylor Made Wheels
    323-567-3998
    i spoke to Charles there. Just be VERY VERY carefull as to how you talk to this guys. He is an old timer that has his ways and is hard to get him to veer away from them. I had to talk to him for a while for him to do a couple of different things for me. It also took a little longer than he estimated but It's very worth it. These have been the best looking wheels i have seen. I know Stazworks make some nice FLATPLATE centers but this guy make them like OEM with the raised section in the middle to give it a more rigid center. Like I all the pics I have are in my Sig line.
    When I had mine done, there were 4 other club members that had them done at the same time so we had 20 rims done at once. The price was $100 for each rim which included cutting your original center out of your rim, makeing a new center, sand blasting the rim where he is going to weld, and welding in the new center.
    Here is a link to a post on Pirate that was amade a while back.
    Hummer post on Pirate.
  10. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I got mine with Esteban and i couldn't be happier.
  11. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    i just got 5 36x12.5x16.5 TSL swampers on old school hummer rims for $250 bucks! im going to put them on my burb once i get my 4 inch lift thursday.
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    stock h-1's have 7.25" of backspacing, to run them on stock axles u must change the backspacing which in slang is re-centering them. u can run these rims in there stock form on a drw d60f. u can run spacers on the rear or a drw d70hd like me. i did a how to on this a long time ago, i'll see if i can find the link. here are some pics.
    stock h-1's on drw 60 & 70
    h-1's w/ rock ring added
    up close pic w/ rock rings added & powder-coating
  13. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Here is mine with stock H1s and a rock rings welded on. This is a 76 with 6" lift and DRW Dana 60 front and Van width 14 bolt rear. If you are starting from scratch try and locate a HD70 like Boz has. It is wider and that is more deirable as i will have to run spacers (2"-3" each side) to get the width I want and when I go to a taller tire it will prevent rubbing the inner fenders on the rear.
