Hummer Rims
Discussion in 'The Garage' started by BurbLover, Aug 5, 2003.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I think original Hummer Rims came with 7" backspacing. Can someone either correct me or verify this? Thanks.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Doesn't answer your questiom, but look .
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Okay, I looked. (Just not sure why.)
    /forums/images/graemlins/confused.gif
  4. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I'm pretty sure it's 7 inches, if not it's real close to that. You either have to have them modified to run on a standard axle (Dana 60 dana 44 etc.) or run dually hubs on the front axle. On a standard axle they will come in contact with your steering components.
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    This gives me two thought:
    1 - Convert front D60 to dually and run rims as made. Then use 1.5" spacers on rear 14B. (Not sure if this would line up right.)
    2 - Convert all rims.
    Any more thoughts?
  6. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I am going to run dually hubs and spacers. I have a Van 14 bolt, also. Haven't done the math yet to see how big of a spacer I will need. The only draw back to this that I see will be if I decide to run a different wheel in the future. Guess I will just have to get a set of Std Wheel hubs as well.
  7. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Any more thoughts?
    Just my .02 is to get the rims modified. /forums/images/graemlins/thumb.gif Like roddzilla mentioned you would have to run those stock hummer rims and 16.5 tires until you decided to change everything back so you could run standard backspaced rims and bigger diameter rims for bigger tires.
    Eric
  8. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    HMMWV wheels are 8.25" wide with 7" BS. They are 8 lug, and 16.5" in diameter. Most come with runflats.
    I am putting stock HMMWV wheels on my truck with the stock 36" tires until I get some stuff sold, and then I'm switching to 42's. The reason I can do this, is because I pieced my D60 together, and I got Dually hubs on purpose.
    Dually hubs add 3" to each side. So I will be running an 8.25" wide wheel, with 4" BS in front, and 7" BS in the rear (essentially).
  9. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    why don't you turn the back around and run 1.25" backspacing, with the fact that the rear is like 2" narrower, that will mean they will look like 2.25" backspacing.... Just a thought! Also, if you use a Dually rear, you can run the rear just like the front and they will match! /forums/images/graemlins/thumb.gif
  10. Aquaman
    Apr 21, 2002
    337
    Kansas City, MO
    [/ QUOTE ]That would be wayy too wide
  11. Batmanjr
    Mar 23, 2001
    1,537
    But you could run rear dually hubs and then run them like the front to be 4" backspacing..... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  12. Aquaman
    Apr 21, 2002
    337
    Kansas City, MO
    Why would I do that? It's just a wheelin rig, I don't really care if the tires match. I can spend the money on other things like an orbital valve, or something like that.
  13. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Hey Burblover... check this out clicky . Don't know if this helps or not. I'm still thinking about going with hummer rims and I would rather pay for custom rims then modify my d60 to a dually setup. Never know what I might want in the future. I might be wrong, but a dually setup seems like it would have limitations, again I might be wrong.
  14. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks. I actually looked at that already. I figured 65 a piece isn't bad. The down side is shipping to & fro. That is why I'm gonna check local to see if someone can do it. Otherwise, I might jsut send one rim at a time there.
    /forums/images/graemlins/burb.gif
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
  16. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Actually I do have something against Daniel. I ordered a set of his PVC beadlocks and it took almost 6 weeks to get them. Not only were they late in getting here, the box that they came in basically fell apart the minute UPS gave it to me. I have not been the only person with problems form here so I really don't recommend going with him.
    On the other hand I had my wheels cut and recenters by the place that Emmotology mentioned. I got it for $100 a wheel but that was a group discount. And you have to provide the rim. I think it's normally 125 a wheel. It may be pricey but well worth it.
    I have pics of them on that post that is linked to Pirate. Look at page 2 towards the bottom. /forums/images/graemlins/thumb.gif
  17. Batmanjr
    Mar 23, 2001
    1,537
    For recenters, just another option, try 4wdfactory! I think they want $50 a center plus install which comes to about $100 a rim normally! I hear they do great work! I modified my own, so unless your brave, I wouldn't do it again! /forums/images/graemlins/thumb.gif
  18. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I sure hope that they spend more time on checking the quality of their products than they did on their business cards! /forums/images/graemlins/eek.gif I've never heard of "Acylene Welding". /forums/images/graemlins/wink.gif
  19. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Here's our current hummer rim recipe:
    Dually front
    fleetside dually D70 rear with single wheel 14 bolt hubs
    Comes out the same track width
    This is really nice if you find a fleetside dually to get all the gear from. Otherwise the axle might be hard to find.
  20. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Stephen,
    Do you have to modify the 14 bolt hub or the D70 to make the rear work or what. Give us more info. I am presently running the D60 Dually Front with a Van 14BFF with spacers to make everything work. I would like to eliminate the spacers if possible, but they haven't given me any problems yet, even with the 42's.
