hummer t-cases
Discussion in 'Engine | Tranny | T-case' started by afroman006, Mar 24, 2006.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    2 NP218's. Driver's drop, 2.62:1 low range, I believe full time 4wd. Aluminum case with standard round 6 bolt pattern and GM 32 spline input and fixed yoke output. Has barb fittings on the front allegedly for a cooler. $200 each
    1 NP242. Driver's drop, 2.72:1 low range, also full time 4wd I think. Aluminum case with standard round 6 bolt pattern and GM 32 spline input and slip yoke output. Has barb fittings on the front allegedly for a cooler. $200
    Located in College Station, TX
