Hummer tires and rims
Discussion in 'The Garage' started by MUD JUNKIE, Apr 7, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    I know you all have read post after post of the sdame old question.I have searched and came up with nothing about fliping the rims around and running them backwards,I have the stock steering setup,no crossover,and the 14 bolt rear.would they fit on backwards? if they did I know it would put them out real far,and have alot of stress on the ball joints (but I'm changing them out this weekend for new ones,since they're bad anyways)and I dont plan on running the rims backwards for a long time. would this work?
    also how are the tires? they are 36/12.5/16.5 muds,any problems with them? are they good in mud? what about balancing?
    thanks yall!
  2. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    I forgot to mention that I got these tires for free,did not pay a dime for them /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You can run them backwards but they will end up with about 1" of backspacing, which is hard on the balljoints/kingpins and will cause the tires to stick way WAY out. </font>
  4. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    so they will fit but they'll stick way out. /forums/images/graemlins/thumb.gifcool I just want to try it out maybe do some mud boggin with them stuck real far out,just like once or somthing to see how'll they do,I'll prolly mount them on regular 16.5/9.75 steel's and sell the beadlocked rim.
  5. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    they will not have a seat for the lug nut on the back face. you can cure this by getting the cast ring from a DRW rim and the correct lug-nuts.
